Discuss How deep should plastic pipe be chased into a internal brick wall with plaster finish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Learning
How deep should plastic pipe be chased into a internal brick wall with plaster finish?
I have plastic 15mm JG PEX pipe which I want to chase into wall.
How deep should I make the chase.
Do I also need to sleeve the pipe. If so what with?
Do I cement the chase or just plaster?
Thanks in anticapation!
Re: How deep should plastic pipe be chased into a internal brick wall with plaster fi
you can chase the brick/block upto 1/3 of its thickness on the vertical plane and 1/6 of its thickness on the horizontal plane.
if possible put the pipe inside a length of 22mm speedfit or rap it in the tube type celafelt lagging. (rap laggging in a tube)
Do not bury plastic pipe in the wall it will cause problems
Reply to How deep should plastic pipe be chased into a internal brick wall with plaster finish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
