Discuss House doesn't need 30kw at present, but might do in future... in the Central Heating Forum area at PlumbersForums.net
We're looking at a new boiler system from regular to combi because we would like to use the space where the hot water cylinder currently sits. We have a large 3 bed semi and have an ancient 18kw Potterton boiler with 7 radiators in the house. Heat loss calculations not yet completed.
We've been told we don't necessarily need 30kw+ at the moment, but for future-proofing reasons (extra bathroom, increased hot pressure at mains etc) 30kw would be fine and not be too large so as to be over-efficient.
Is this sensible?
Subscribed
A two bathroom property may or may not be suitable for a combi boiler ? as the supply of hot water is only really suitable for one outlet at a time it really depends on your usage and the occupancy, the heating load is often adjustable and can be down rated in the boiler settings , house builders often put in large kw combi boiler in a 4 bed property with a family bathroom and a ensuite be guided by your chosen engineer. Kop
Subscribed
Anywhere from 25kw-30kw will do one shower.
If you’ve got the mains flow rate 20lpm+ and put in a 37kw+ combi with flow restricted showers, you might get 2 showers at once.
37kw combi - around 14lpm hot
14lpm hot mixed with cold for shower - comes out around 20lpm.
2 flow restricted shower at 10lpm each - 20lpm.
But it’s very close.
A better expectation for a 37kw+ combi is a shower and hot tap running at same time.
You will also likely need a gas pipe upgrade.
Thanks for the response. Currently got a 22mm pipe, will that be enough?
Subscribed
Depends on the length of run from the gas meter and what kw of boiler you end up with , but be prepared to upgrade with anything higher than 24 kw and a very short distance. Kop
Reply to House doesn't need 30kw at present, but might do in future... in the Central Heating Forum area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4 times since.
It’s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
