Discuss Hotter = Less Gas????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stefan-west1
Hi all hope someone can help me out here, currently have a combi boiler in our rented house, but we have no thermostat, therefore we've been leaving the heating on from 5am to 11pm with the radiator dial on a low setting just to keep the house warm, however because of the very cold weather we've had the last couple of days, it was getting so cold we decided to just whack the thing up to full, which is how it's stayed for about 2 days now.
What I've noticed is when it was set on low, we were using around 0.8ft3 of gas every hour on the meter, however with it on full, its dropped down to around 0.4ft3 per hour!
I only have a very very basic understanding of how a boiler works, can someone explain to me why I'm suddenly using less gas?
It could be down to the fact that you have already warmed the structure of the house using the boiler on low, and now the boiler is up on full, it does not have to do as much work.
I would check what gas you have used for the whole day when boiler is on full. I find it hard to believe you would use half the gas you did when you had the boiler set to min.Try the test again and record total gas used per day. Please post results.
it dose work out cheaper i've found to keep the house at a constant tempreture instead of heating it up fully and alowing it to go cold to heat it back up again
Reply to Hotter = Less Gas????? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hi all I have a Vaillant eco boiler at a new house I moved into last week. It’s a combo boiler and the last boiler I had was old (and much...
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer &...
1K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
