Discuss Hot weather causing smelly bathroom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In anyone's experience, does hot weather have an impact upon air admittance valves?
We have an AAV in out WC (see photo) and in the hot weather the bathroom stinks of sewage. Any ideas of what could be causing this?
It is best to drop some bleach down each trap inc.all bogs and washing machine traps after putting clear water down first.
We do this in the holiday lets in hot weather and when we close up for the winter and leave the plugs in sinks and basins
The Mk1 human nostril is often the best detection device here.
It's rare but the aav can fail open, more common when used outside.
It can also fail closed which will pull the trap out of the basin.
But if it's hot weather related then evaporation your best bet.
Reply to Hot weather causing smelly bathroom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
