Discuss Hot water tank and pressured pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Delboy21
I am fitting a 3 bar pump to increase my poor pressure and all the info says to connect the hot side inlet of the pump on the pipe coming out top of hot tank I would think that if. I did that wouldn't it just keep pumping the water back up the vent pipe to the cold water tank thanks for any advice
you need an s flange
also you need a dedicated cold feed from your cold water tank
The pipe coming out the top of my hot water cylinder comes out on a 90 degree bend goes for about two feet and then it t piece's one going down the other going up into loft and bends into top of cold water tank I'm under the impression if I put the pump inlet to the two feet part wouldn't it just pump up the pipe and into cold water tank
yes it would thats why you need to alter the pipework to suit
what are you trying to do boost all hot water outlets?
Hot and cold colds no problem have it sussed just he hot just doesn't seem right how would I reroute pipework
leave the vent (top pipe) in place and cap the one going down (just after t)
connect the s flange to cylinder
take the s flange port to pump inlet
connect the pump outlet to the pipe going down that used to be connected to the pipe going up
hope this make sense
Brilliant finally understand great info. But excuse me don't know what an s flange is or does can you explain thanks for your help
Brilliant finally understand great info. But excuse me don't know what an strange is or does can you explain thanks for your help
you mean the s flange ?
Cheers mate that's great you have explained it well while I. Am talking to someone clever can I ask you a question it's a twin impeller pump when I connect the cold side can I just cut the cold pipe coming from loft storage tank and connect to pump and back out pump back to the pipe
are you boosting all the cold tank feeds if so just make sure you tank is big enough must be 50 gallons (225L) +
and yes the one that supply's your tank cold to your outlets but dont boost the cylinder cold feed
I still looking again at the hot water system explanation that means there's no connection to the pipe going up to the loft
as long as that pipe is connected to the cylinder your fine (you need that as its the vent for the cylinder)
you dont need to touch that
But the pipe coming out top of tank goes to the pipe up into the loft if I take that pipe cut it and send to pump then to the pipe going down the tanks then not connected to the pipe going up to loft
hope this helps
"leave the vent (top pipe) in place and cap the one going down (just after t)
hope this make sense"
have a local plumbers number to hand, you may well need it, take care installing your surrey flange, too much force can crimp an old cyl
Just get a local plumber to do it for you. You sound like you are struggling.
Wow 3bar press. You must have a basement or a few flights of staircase.
Yes the pump and @3bar has to have its own independent Feed or feeds.
Otherwise you'll have the system inducing air when someone turns on a hot tap and you'll probably find the shower spluttering if you "tee" into other pipework to frrd the pumps supply.
Reply to Hot water tank and pressured pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
