Discuss Hot Water Storage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Electro-tech
Hi Guys, I have been asked to increase the Hot water storage in this bungalow, I am a electrician firstly, a Electricians forum member, and I carry out Plumbing to a point within the regs. The property is all electric ,with no gas available in road. They were advised to have a oil fired or propane heating/Hot water system installed , but they thought best, to make use of what was already in place.Then someone had installed a 3 bar whole house pump for a power shower & guess what, your shower can only last for about 3- 4 minutes with a immersion heater. I got involved ,when I rewired the property.It is not possible to install a larger Hot water cylinder in the existing cupboard on ground floor. I am open for any solution, my first thoughts were to install another Combi cylinder in the roofspace. Having said that, can I link the 2 cylinders together ? Best way to link them ? Open vent on existing cylinder will need to be extended ? Thanks in advance for your valued replies.
Can't believe they were advised to go with oil / propane!
An air source heat pump would be there best option with a new cylinder installed, it would be a lot cheaper to run than all those other options
soalr hw panel and solar cylinder, free hot water! no brainer, nought wrong with oil boiler imho.
sitck a direct unvented cylinder in the cupboard, other space or loft (only if timbers can take the load). Fitted by a G3 qualified plumber of course.
Reply to Hot Water Storage in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated heat source and a oil boiler. The problem the hit water cylinder doesn't have a stat thus why the hot water is roasting hot but there is a pipe stat on...
Hi all, I have an OSO Direct 210 hit water cylinder installed in my home, with 2 switches (on/off; and boost). The boiler is for hot water only (rads are electric). In the 5 years that I’ve lived at this property, I’ve never once turned the boiler off; however, with soaring energy prices, I’m...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot water to our plastic header tank in the loft every time we turned the heating on. We first noticed an issue with a leak in our bedroom ceiling which we...
