Discuss hot water low flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
webbm
Hi
I have potterton he 28 since yesterday the hot water flow through the boiler is very low and make whistling/hissing sound coming from the boiler.
I turned the boiler off and the flow is still low on the hot tap and still makes a hissing sound. Tried all the hot tap throughout the hose and it same issue.
Cold water flow is is still good and central heating is working fine any ideas what it could be?
Think there is one thing you can try. The cold pipe should be the second pipe in from right. Also look in the instructions and look up how to remove the mains cold inlet filter. I would be very upset and disappointed if you opened the boiler case. Your not allowed to and be risking your family!
DHW Filter (Fig. 79)
13. If the flow of domestic hot water is diminished, it may
be necessary to clean the filter
found the above is it worth asking a boiler engineer to check it for me because the one I called out was not sure what the problem was he said it could one of 2 parts and would he need to change both to find out the cause he wanted £320
A decent Gas safe engineer should be to identify the fault without having to resort to sticking parts in hoping it would work Why not post up a request in the looking for an engineer section of the forum (link is below)with your location, you are more to get a decent engineer to come and have a look and advise you correctly.
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to hot water low flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello, I’ve been doing my first refurbishment is a two bed flat with a bathroom and ensuite . Learnt a lot and been grateful for input’s...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
