Discuss Hot water flow is poor want to improve it in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pull out nozzle types I think are all only rated for high pressure. They are very restrictive.
Ordinary modern 1/4 turn kitchen mixers are generally poor enough poor, although some strangely are okay.
The flexi hose tails are small bore, then the body of tap is same and the ceramic works have only a small max opening. Then the spout really adds to the restriction - particularily due to the hot having to go through a small bore pipe in middle of spout, - which on pull out type is a flexi. Add to that an airator at end which can be only for high pressure. Check the airator isn't partially blocked by unscrewing it
your flow would triple with this tap with copper tails , ideal for gravity systems
Or any gravity rated tap
Reply to Hot water flow is poor want to improve it in the Plumbing Jobs | The Job-board area at PlumbersForums.net
