Discuss hot on/hot off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
2retrievers
i am working on an old system,and have been asked to replace a switch which is broken that controls hot water only or heat and hot water it is on 22 mm copper ,tenant says it had a black plastic switch on it before it broke,any ideas where i may get one from or a alternative,
2retrievers ... No chance of getting any kind of replacement I'd think! What you describe reminds me of a very old BGas 'budget' system! Manual diverter valve and all!!! Is it a three way valve you're talking about?
cheers just thought someone may have one buried away in a shed somewhere,it is a old system and the tenant is trying to put off the inevitable,thanks anyway.
[DLMURL="http://www.rega-uk.com/pages/default.aspx?pageID=3689"]http://www.rega-uk.com/pages/default.aspx?pageID=3689
T[/DLMURL]his may be what you want. I know that BG still has them as a stock item.
Cheers
Well I never!!! Nice one gasman10... I'd never have thought you could still get a hold of the manual diverter :)
Reply to hot on/hot off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
Hello everyone, I'm facing a rather complex situation and I need your expert advice. My neighbor and I share a boiler for hot water, and we have...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
