Discuss Honeywell V4073A 3 Port Motorised Valve Wiring question in the USA area at PlumbersForums.net
Hi
i checked the wiring colours are the same from the junction box to the current 3 port valve, as the new one. But although I could turn off the house mains, I would prefer not to, is it easy to tell if the wires are live, using a multimeter, ? Have an isolation switch, but not 100% sure if that isolates everything relating to this valve.
thanks
If you have a multimeter very easy take off junction box lid check live supply to box (makes sure multimeter is working!)
Switch of isolator take out fuse check nothing is live in junction box.
Current guidance of dead testing is to use approved test equipment, a multimeter is no such equipment. Should be a test lamp or 2 pole voltage tester, including testing equipment on a known source.
This is amazing, all I want to do is see if the wires are safely isolated so I can replace the 3 way valve......as I can’t find an answer I will just turn the mains off, really hoped to get a reply such as check wire colour A with wire colour B and check if voltage zero......
This is amazing, all I want to do is see if the wires are safely isolated so I can replace the 3 way valve....as I can’t find an answer I will just turn the mains off, really hoped to get a reply such as check wire colour A with wire colour B and check if voltage zero....
I could tell you which wires to check, but as you mention “safely isolated” it would be a breach of h&s regulations. I wouldn’t want you to injure yourself or worse. This is why such procedures and regulations exist, sorry if it’s not what you want to hear.
Also in a wiring centre like this - if someone’s done something odd (more often than you might think) , then you could test for dead but power could come from another source as you are working on it...
Reply to Honeywell V4073A 3 Port Motorised Valve Wiring question in the USA area at PlumbersForums.net
