Discuss Holesaws sizes for stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumermicky
What sizes of holesaw bits is a plumber most likely to use? e.g for stack/cistern?
The best thing to do is just buy a set with loads of cutters so you don't come unstuck. However, most of these sets are cheap and nasty and struggle going through mdf let alone tresper panels! I have one of these sets for thin materials but also have several higher quality ones for common sizes. These being 18, 25, 36, 44, 55 and 120. I have found Starret or Bosch to be the best. Of course we are only talking about holesaws here, masonary bits are a whole new world!
If its for cuttinig hard tiles then you need diamond drills we sell a lot of 110mm to get stacks though Porcelain tiles.
http://www.*********.com/jpgs/125mm.jpg
Cuts out the tile for the loo pan
http://www.*********.com/bigholes/smaller/Dsc08202.jpg
Also good for extract fans etc.
Reply to Holesaws sizes for stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We want to change the mirror in the bathroom so I need to drill a new hole through the tiles. The tiles were dotted and dabbed as the walls were...
2K
What drill bits do you guys use for drilling thick porcelain tiles? Got 4 bathrooms to second fix with 10mm thick tough porcelain tiles. I’ve...
4K
  • Locked
Here they are! Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart...
2K
365drills
  • Locked
Brand new for April 2016. Launch of boxsets for drilling holes into very hard porcelain tiles. Two sets have been revamped. The third is...
365drills
  • Locked
E. K. Wilson of London is a prefered stockist of PORSADRILL diamond core tile drills. If you need ********* core drills in...
365drills
