Discuss High temp prv & condense pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TFGplumbing
Hey guys Iam fitting a boiler where the prv and condense will be removed by a high temp pump.
Question is... does the the pipework that takes the condesate/prv have to be pipe in high temp plastic waste pipe? Like on an invented cylinder
Reply to High temp prv & condense pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
