That's roughly twice the volume of gas that I would have guessed based on your description the house and usage patterns. I'm assuming you're in England not the North Pole, of course.
The two areas I'd scrutinise carefully are:
Firstly, the UFH, in particular what's the specification for the construction of the floor? If there isn't enough insulation under it, or there is two much insulation on top of it, UFH can be a really money-pit.
Secondly, the hot water. How much do you use per day and how is it programmed? Have you got a hot water leak somewhere?
Unless your house is essentially uninisulated or you leave all the windows open the whole time, the amount of gas you are using if it were all dissipated as heating would be baking you all alive. This is why I'm suspcious about the hot water. You might be pouring money down the drain, literally.
There is always the possibility that the meter is faulty and is over-reading. Also, are you sure that your meter is not also supplying a neighbour?
Once you done some basic checks, I suggest you get a heating engineer to do an energy consumption and loss calculation for your house to see how much it should be costing you. They'll also be able to check, approximately, that the consumption rate indicated by the meter matches the rate expected when the boiler is working.
I'm probably repeating stuff others have already because I got interrupted for several hours while typing this answer.
The UFH is set in a 65mm liquid screed, under which is the celotex insulation all to regs and done professionally and then porceline tiles on top. The UFH in this cold weather does take around 2.5 hours in the morning to get to temp, but what I notice is that it rarely comes on throughout the day (monitoring the heat call from evohome) and back on for a top up 30 minutes in the evening.
The hot water is puzzling me to be honest, it was set since we had the system installed (2 years ago) to come on every morning at between 5-6am. But I have turned this off the timer around a week to see if this had any impact. We still have lots of hot water (no one complained that water gone cold). What I have observed is that occasionally the hot water pipe leading from the valve to the tank is hot so this telling me that the boiler is at times automatically reheating??? or is this the tank automatically asking for the water to be heated as its dropped below a certain temperature?
