Discuss Hep cutters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Londonluke
Fancy some nice cutters. Have some cheap red plastic ones that feel 'cheap"
want to add some "bling" to my tools !!
5.9015, 5.9022 - Rothenberger PLASTICUT 15mm - 22mm Plastic Tube Cutter
Simply click the PLASTICUT into place and grip FIRMLY, rotate around the pipe in the direction of the arrows. The pipe will be cut, squarly and cleanly after 1 - 2rotations.
* Simple to use
* Single - handed cutting action
* Ideal for confined spaces
* Safer to use than saws or shears
* Tailor made for professtional and DIY use
* Clean, square cut through all types of plastic pipe
* Comprehensive size range available
* Replacement blades available
* SAFETY NOTE Please replace safety insert after use
http://www.tradecounterdirect.com/productinfo.php?pid=902&cid=121&cat=HAND TOOLS: Pipe Cutters&pg=1
productinfo.php
hi , new to this forum so hello to you all.
i tried this type of plastic pipe cutter and found it very poor. the ex-plumber/merchant tried it as well with no joy either. he said the he will not be restocking them !:confused:
I had 32mm cutters and agree that they are useless. I have heard that the 15 & 22mm are very good though.
Steve
i have found the more you use these cutters the worse they get only cutting half the pipe (time for the bin)
Reply to Hep cutters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
