Discuss help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jamieinnes
I want to move the toilets in a warehouse but they will be a long way from the existing waste pipe , Is thow far will here a way of doing this ?? bigger flush/ pump ?? its about 35 mtrs and around 3 bends
you will need a new drainage system, it is too far away for a macerator. You could probably get a commercial sized pump but that would no doubt cost a fortune if there even is one which could cope
A new drainage system split with a manhole then the run to the loos. The manhole/s will allow you to drop a part of the pipe run into it, with the sewage exiting at a lower level and allow for future access for cleaning blockages etc.
Either way probably be easier to dig a big hole round the back and use that instead for a loo.
Saniflo pumps horizontally maximum of 50 metres. Well within your relocate area. Other Sani products go further up to 100 metres. These falls are based on 1:100 fall. If you increase the gradient you can go further.
Reply to help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
