Discuss Help! Warm Air heating doing strange things! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any advice gratefully accepted - warm air heating system with Multicolor 028kw oil boiler (must be 30yrs old) - air vents in rooms blowing in warm air (not as hot as usually expected) and vent in hallway which usually sucks air out of house is blowing IN cold air - Cannot figure out why. Fan is going round ok but cold air being blown in instead of taking air out of house. Any ideas?
Reply to Help! Warm Air heating doing strange things! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up blowing/melting a hole in one of the pipes. I repaired this by putting in a new stretch of pipe in and just connecting it to the existing pipes with two...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but I'd like to do it myself if possible. All images for system here: https://*********/a/ngPQkre Last winter the temperature switch on my boiler...
Butchy10
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in the garage which is fully pumped to the TS, the system has two pumps both basic 3speed Grunfoss, one on the boiler return and the other on the CH flow...
1K
