Plumbo
Hi folks, I have a plumbing conundrum in my new house and was after some advice and explanation of the defect.
Type
'Y' Plan system, Potterton FF40 boiler (2002), grundfos pump (2008) located in an upstairs bedroom cylinder cupboard. Original system was warm air heating, boiler new install 1992.
History
I moved into the house a few months ago, surveying the loft I noticed that the Cold feed and expansion cistern for the central heating was boiling hot. I asked the owner to get this fixed before I bought the place.
He came back with a plausible fix of a blocked cold feed pipe (friends experience), and had 'fixed' the problem. Checking the fix, I noticed that the guy (BG apparently) he got out to work the problem had ran the cold feed into the open vent pipe. A heating engineer I phoned said it was not correct but would be safe enough; the cistern was no longer getting hot and overflowing.
Once in the house I had somebody around to change the cold feed pipe and revert the system back to normal configuration. Once connected the F+E cistern got boiling hot again with the O/V and CF pipes hot aswel, defo no blockage!!
Problems
Due to current config of C/F running into O/V Air in the system is driving me nuts, I gather because it has no vent or way of escaping.
Observations
-The air glooping is only when the three way valve is porting to the DHW cylinder not the C/H. It only happens when the cylinder is almost at its pre-set stat temperature 65.c
-The boiler is set to 1 but still kettles (with silencer added)
-The pump speed is also set to 1
-The open vent is approx 5' from highest pipework to the top of the CF+E.
-Cold feed Pipe pipe run is approx 3' more plus 3" of water in the tank.
-Pipe run =Boiler Flow side, O/V-C/F distance 1 m, C/F- Pump (suction side) 30cm. Pumping downwards.
Questions (shot in the dark)
How can I get the air to escape?
Is lack of header pressure causing the water to boil early, hence glooping, kettling?
Is the pipework config wrong i.e O/V is too far away from C/F, neutral zone etc? How can this be resolved in a little cupboard. ref J Mac pumps
A link to a set of Flickr photo graphs of my cupboard is (if) available.
Sorry for the long winded thread. Any help would be gratefully received.
[/IMG]
Type
History
Problems
Observations
