Discuss Help - changing wireless thermostat in the Central Heating Forum area at PlumbersForums.net
I recently posted on here as I was having problems with my wireless thermostat and receiver, turns out the receiver has developed a fault.
I have decided to change the old set up for a new receiver and wireless thermostat.
However the wiring set up is different on the new unit ( a Honeywell/Center unit EHE0200361 ) the old unit is a Salus ST620RF
Boiler is Worcester Greenstar CDI
Could anyone help me with the wiring please.
I have attached photos of the old and new receivers.
many thanks
Blue to n
Brown to l
Earths together in a chock block
Black to a (this should be into the com port on the old)
White to b
That’s a bit of a guess as can’t make out the writing
Thanks Shaun,
Do I need to link both the ' L ' terminals together on the new Center box ?
Which writing can you not make out - I will take another photo to clarify if this would help
many thanks
Thanks Shaun,
many thanks
No just put the wires on the left L
And the back wire there should be writing below the terminal block
Thanks for that.
The writing on the Salus connector block reading left to right is
COM NO Earth Live Neutral
regards
My info then is correct
Thank you. Much appreciated :)
you may find youll struggle to get the two cables into the honeywell as you need two neutrals and two lives which look 1.5 maybe 2.5mm. one drawback with this receiver is very small wiring terminals. black and grey no problem as one cable per terminal. the two browns can go one each into the live terminals, the right hand live is just a common live youd use to link to terminal A if you were not doing no volt switching. just be careful with the two blues into one terminal dont have too much bare cable showing on the neutral and live terminals closest together very easy to short out
Great thanks for the update
Reply to Help - changing wireless thermostat in the Central Heating Forum area at PlumbersForums.net
I have a ideal logic 30 boiler ,the thermostat receiver looks to have died ( no lights on wired receiver ) I believe this need# replacing but in...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hi , My wireless thermostat, has become water damaged and is toast , no longer displays anything (long story), it is a boss bps242rf and the...
Deleted member 120897
I have bought an old house in rural France and it has an oil tank and Unical oil powered boiler (Italian I think). Its a beast of a thing but...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar...
2K
