Discuss help/advice needed please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
swanny944
I have a bath tap with what I believe is called a "diverter" on for the shower - this is by way of a "plunger" that you raise & the water is diverted to the shower hose-however the plunger will not stay up - does this mean a complete dismantle of the tap & a new one fitted or can it be repaired "from above the bath" - thankyou
For the price you can pick them up for Id be inclined to just change the full tap, repairing it could be more time consuming than a replacement. Im not a fan of throwing things away all the time but hey ho
Replace the tap. Job done.
BOD's post was aimed at MK Heating. Don't worry about it.
thank you for your reply - the reason I wanted to know if a repair was possible is because it means stripping a lot of things out to get under the bath to fit a new tap - if no repair is possible I have a feeling that the tap will have to remain with diverter not working
It can be fixed from the top. Post a picture of it and i'll tell you how to get into it.
hi tamz - thanks for the reply however for whatever the reason it won,t upload my pics,i,ve even tried reducing the size but still nothing - the only thing I can add is that it is a single pillar "ideal standard" bath tap
HI AGAIN TAMZ - I have just googled it & found a pic-looks identical but the lever is slightly different - it is "ideal standard B7890AA "hope you might be able to help - thankyou
Reply to help/advice needed please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Hoping someone can help. I have the bath tap as shown in the picture. I need to get the bit that sticks out (little round handle) off. The tap...
Hi All I found this forum quite by chance this afternoon whilst looking for an answer to a plumbing question that I have following a rebuild of...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi I fitted a bath/shower 12 years ago and a few months ago it developed a leak. It was basically at a coupler on 40mm solvent where my new...
2K
