Discuss Heatslave 25/32 No HW in the Central Heating Forum area at PlumbersForums.net
Hi guys just installed an oil 25/32 external Worcester Bosch Heatslave External boiler.
I can't get hot water. Central heating is fine. Comfort rf fitted and seems to be working fine. Link wire has not been removed.
The sensor is not registering the dhw lts per minute display.
Any help right now would be greatly appreciated. Thanks Ryan
Hi thanks for your advice. I think it's the flow turbine. Looks like a warranty job for WB.
You sure it's a turbine and not a flow switch? Either way call WB in the morning. Just to inform you some of the new Firebird combi's use a thermistor on cold inlet to PHX instead, less problems to occur than a flow switch
Reply to Heatslave 25/32 No HW in the Central Heating Forum area at PlumbersForums.net
