Hello folks,
Apologies in advance, I wouldn't be overly read on this!
I have a simple oil fired home heating system with a basic on / off dial timer and TRVS on the radiators. The timer is broken, in that it's turning about 1/4 that it should thus timing very difficult.
Ideally I'd like to upgrade to thermostats, separate water controls etc but I understand that isn't possible without a separate pipe going to the boiler.
I was hoping to replace the timer with one I could control remotely. In short, what I have is this.
https://www.amazon.co.uk/Hour-Socket-Box-Mounted-Timer/dp/B001XQ5ZMS
And I'd like to replace it with this.
https://www.amazon.co.uk/Optimum-OP-SBWF01-Enabled-Socket-Switch/dp/B07843J914
Is this possible or is there a better solution?
Many thanks.
Many thanks.
