Discuss Heating has stopped working boiler clicking repeatedly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
my house immersion heater has started clicking repeatedly. My radiators are heating fine. Hot water works fine as well. I noticed the pressure gauge was at 0. I bled all radiators and refilled the loop with water so the pressure level went back to 1. I am all out of options. Help!
Thanks for responding. It is a Range Tribune HE. The sound is possibly a valve switching or failing to switching. As for a reset button I do not know. There is a switch similar to a light switch which was off. I tried to resolve this by turning the switch but this had no effect.
Yes but what I think they are saying is you’re not sure of the difference between your boiler and your cylinder so if you’re not sure there then dealing with a system full of water could be problematic. I’d get someone in
Last question, is it possible to turn of this boiler so it doesn’t click anymore. I understand this will not allow me to get the boiler function anymore but will at least allow us to get some sleep until it is repaired?
Thank you very much for all your help with this.
1. It won't be covered by the 10 year NHBC guarantee, unless the property is less than two years old, when it might be covered.
2. You need a plumber with what is know as a G3 qualification.
3. What you have in your picture is not a boiler, it is an unvented hot water cylinder (hence the need for a G3 qualification). It is heated indirectly by the boiler, and will probably also have 1 or 2 electric immersion heaters for use should the boiler fail. However, I can't see a suitable electric lead in your picture.
4. I can't tell for sure, but it looks as if the silver coloured motorised valve, which is clicking, controls the flow of hot water from the boiler into the coil inside the cylinder. TH heat from this coil is what heats your hot water.
5. If you turn the requirement for hot water off at your programmer, the valve will probably stop clicking.
6. If the boiler is no longer heating the cylinder, see if there is an electric immersion heater fitted. Then, if you do want the water heated, find the switch for the immersion heater and turn it on.
Reply to Heating has stopped working boiler clicking repeatedly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
