Discuss heating egineer wanted urgent NE31 area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andy666
Hi all just wondering if there are any heating engineers NE31 area, had a problem with my boiler last few days which has now totally packed up its a potterton performa 24 have rang about 8 local but not 1 has even got back to me any help appreciated second day now no hot water or heating.
In in north Tyneside if that's any good? I've posted a reply to to your other message too!!
have you got it sorted yet
Hi, yes hopefully later today its the pcb which has gone thanks anyway.
Just a quick update jefaz came out within 1 hour of me posting on here told me the problem was my pcb he came back today fitted a new one everything back to normal only took him 10 mins many thanks to him and all who answered my query forums like this are a god send having left 8 messages over the weekend to various LOCAL plumbers/heating engineers not 1 even had the decency to ring back... definitely recommend jefaz in future and will be ringing him after xmas to service my boiler once again thanks for all the help... merry xmas and all the best for 2012. andy
Reply to heating egineer wanted urgent NE31 area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler up until now with regular servicing. When the heating is turned on the boiler ignites and looks to start up but then a few seconds in, knocking sounds...
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at...
J
Hello, hoping someone can advise me. My boiler stopped working - no hot water or central heating. Called out a company who came and assessed the problem as being that the hot water element in the immersion tank needed replacing. (I don't know exactly what it is called as the company has still...
Johnno1966
J
