slingshotjim
Hi, Ive an ESP 11Kw heat pump installed correctly, I hope, only issue perhaps is that its a long way from the100l buffer, pipes fully insulated and thro the garage tho....
Its all connected to Wundafloor over panel ufh, not much insulation underneath cos of heights etc, something I regret now mind, the overpanel kit is designed for this, polystyrene and an aluminium foil.
Wen it kicks in, it uses 6 kw approx with temp 41 in 44 out approx, its that for 40 mins then goes to 1.5 kw for 5 mins then back to 6.5, basically in 2 hours at 5 deg outside temp, its at 6.5kw for1 hr and 15mins and at 1.6 for 45 mins, Wow thats expensive to run, does that sound right, i thort it would be a lot less than that..... Is the controller set ok Im thinking, It uses 6.5kw even if only the bedroom stat is on, It would be cheaper to use elecy rads! Any one any ideas, Cheers... Its set at 45deg, Ive got an Eccocent ashp 300l cylinder doing the dhw so not trying to hard with temp I thought, It loses about 7 degrees thro the pipes from pump to manifold but that wouldnt effect the KW Draw just the temp in the rooms... Any thing I can do..... I thought a cop of 3,9 I think they advertise ment at 7 deg outside it would take about3kw to reach an 11kw output, have I got it all wrong... is it to smallpraps...
any help appreciated, Jim 07980749925
