Discuss Heat Link Cable Length in the USA area at PlumbersForums.net
Can I connect the Nest Heat link unit to the boiler with 25M of cable to move the Heat link unit closer to the centre of the house and therefore the Nest controller. The boiler is quite remote and the house has thick walls which block the signal.
Yep not a problem will need to be a min 4 cores so I would use 2x 3 core twin and earth cables
Reply to Heat Link Cable Length in the USA area at PlumbersForums.net
