- Messages
- 3,324
Hi all,
25 year old boiler need replacing.
Existing boiler, 220 kW doing Aged Care Facility.
I want to install a condensing boiler, but are worried about not being able to clean the system efficiently to not cause damage to the new boiler and void warranty.
The best option I can see is to have a plate heat exchanger between the new boiler and the existing heating system.
I would also have a air dirt separator installed on the existing system return piping prior to the plate heat exchanger.
Any Pros and Cons?
System to be installed - probably 2 x 100 kW boilers in cascade.
What are the chances of the plate heat exchanger blocking up?
I don't want to take the chance of installing a hydraulic separator and blocking up the boiler heat exchanger.
Any Pros and Cons?
