Discuss Harveys softener question in the USA area at PlumbersForums.net
Murdoch
Res.Electrician
We've had our softener nearly 7 years - over the last year or so it looking like this:
My question is why is the salt appearing like this?
Thanjs
I’m guessing it could be overflowing and small amounts of water is passing through the seems
Have you tried giving it a decent clean eg removing it and washing it out ?
When was the last time you added salt to it
You should have an instruction manual telling you what / how to clean it out
Harvey are a great company to deal / speak to if you get no wear with cleaning it
Yes, this is called Efflorescence and occurs naturally when water, with the salt (brine) now held in solution, migrates to the surface, then evaporates, leaving a coating of the salt.
You just need to clean the salt from around the salt block access. If it is possible (easy access) leave this cleaning until just before you replace the salt blocks. I usually remove my Harvey's softener every two/three years and give it a good clean, especially around the inside of the bottom of the softener. Harvey's will probably do it, for a fee😱
Top man - thanks for that - excellent advice - I'll update the thread when I have time to try this.
Reply to Harveys softener question in the USA area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Rad is only a few years old. Paint is flaking away at the top curved section and it looks like faint spots of rust where the rad is now bare.
