Discuss Hammer arrestor on dishwasher? in the USA area at PlumbersForums.net
I have some severe water hammer going on. Behind the bath upstairs where I cannot access the pipes. It is is mild when a cold tap is turned off or the toilet is flushed BUT it's horrendous when the washing machine and dishwasher run. I have bought an arrestor to put on the washing machine but how would I connect one to the dishwasher? It's integrated and where it connects to the isolator it's an aquastop. Can the arrestor be put between an isolator and an aquastop?
I have a pressure guage on order to see if our water pressure is too high before getting a plumber to look at maybe putting in a PRV. Combi system so all on mains. It's only the cold causing the bang.
Thank you!
Thank you!
You should have a shock arrestor fitted If your incoming supply is above 3 bar then a prv is recommended . Kop
Thank you. We measured the incoming water pressure today and it’s at 3 bar. Would that need a prv?
I ran the dishwasher today and then the washing machine and it’s the washing machine causing the really loud bangs. I am hoping the shock Arrestor is enough to calm it.
hubby is not keen on losing the pressure for the showers.
Reply to Hammer arrestor on dishwasher? in the USA area at PlumbersForums.net
