Discuss grundfos two speed super 4 circulating pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MACCA104
Hey guys,
My central heating pump has jammed i think,any idea how to release it? 2 out of 3 rads upstairs are hot but the other is luke warm and downstairs are all cold. even the microbore pipe below the valves are cold.
i think my pump is on its way out anyway but just wondering how to get it going again?
any help is much appreciated
ta
You could try hitting it with a hammer or taking the big silver screw out and put a small screwdriver into the shaft and spin it.
This will only work if it is a bit dirt jamming it or a weak capacitor.
More likely the motor is away and you will need to replace it.
Grundfoss are regarded as best and are more expensive but any make will do the job.
Take your pick from the likes of these. Any will do (not the bronze one) or shop around or get a plumber in.
http://www.bes.co.uk/products/105.asp
Reply to grundfos two speed super 4 circulating pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
