E
Edgy
Hello, I've just replaced an oil-fired range with a wood burning range. I have installed a gravity circuit in accordance with the maker's spec. I have water flowing very nicely around the circuit, however, it is returning through the cold water feed rather than the gravity return as the heated water is bypassing the sink radiator and water cylinder and venting direct into the f&e. I assume this is likely to be due to an air lock in the gravity return and wondered if there was any way to remedy without draining down and refilling.
