Discuss gradual slow hot flow all taps in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
This is probably a basic one, but just wanted to check. Hot water flow to all taps has gradually been getting slower over time and the thermostatic shower now needs to be turned up hotter to get a reasonable shower temperature. Its a vented cylinder heated by an oil boiler and the cylinder stat is set to about 62 degrees. The cold feed all seems to be ok.
We're in a hard water area and from what I've read I suspect that the hot water feed from the top of the cylinder might have a build up of limescale that is limiting flow. Does this seem the most likely cause? and given that may be, can I check this without draining the cylinder? (i.e by shutting off the cold feed and then draining the hot taps?)
Appreciate any help,
Terry
Is the vented cylinder fed from a cold water storage tank, should be if its a vented HW cylinder. If the cold water is also from the CWST and is OK then worth checling for limescale build up as you suggest, and yes, just shut the cold water supplyw to the cylinder and open the lowest HW tap. Don't follow why the thermostatic shower setting needs to be increased except that the HW temperature isn't 62C, maybe check this with a household thermometer.
Thanks for responding John. Yes, its a standard set up with cylinder fed from cold water tank in loft. With regards the shower, it is fed from the same hot water outlet from the top of the cylinder (tee'd into 15mm to the pump - not by me I hasten to add). So my thinking was the hot restriction and low flow compared to the cold meant I had to turn the hot higher on the shower valve to get a reasonable shower temp). Although the flow is low, the temp from the taps seems hot enough ... just slow.
Assuming the shower pump is a twin, with cold supply from the CWST & the hot from the HW cylinder and the mixed flow has gone slow plus the fact that the (Hot) flow from the taps is also slow then yes, remove the cylinder HW outlet pipe and have a look.
Yes, that's correct John. Many thanks.
Unfortunately, its really tight for room and the way its been plumbed will make it tricky to get any movement on the pipes, but hopefully it'll be a little easier than it looks.
Thanks again.
Reply to gradual slow hot flow all taps in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
I recently had an eco tec plus 836 combi installed as part of an oil to gas conversion. One thing I can’t work out is why the bathroom sink hot water flow is 12-13L per minute with at 44c and even hotter. However the nearby bath freestanding tap is 8-9L per minute at this temp. Both taps...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
