Discuss Glowworm 30cxi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
woodsy
Been out to above boiler, which is periodically blowing the 3amp fuse in the spur, nowt on the actual boiler. New fuse in and up the boiler fires and works good as gold for an hr, or two then bang again. Anybody come across this before and can give me a heads up ?
A common fault on these....... remove the moterized head and give it a shake to check for water ingress as it leaks through the spindle causing either the fuse to blow or the rcd to trip, but it could also be other things causing a short....... but give it a try
Reply to Glowworm 30cxi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
1K
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
