Discuss Glowork ultimate 60ff lighting issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mrplumb
Hi everyone and thnak you in advance for any help
I have the above boiler for the last 2 weeks this is what is happening:
Boilder function [appears to] be 100% normal when cold then when it gets really warm following issue happens:
main burner shuts off
pilot light relights immediately
main burner shuts off again [almost] immediately [1/2 seconds max]
and repeat constantly
but heating still works
pcb was replaced about 6 mnths ago, but you can hear it clicking, or something clicking, maybe a relay?
thanks
It is NOT A Glowork anyway - i am an expert in all these type of boilers but i think your going to get pulled as maybe ur not qualifeid - if the mods pass you I will help CHK QUOTE=Mrplumb;588785]Hi everyone and thnak you in advance for any help
thanks[/QUOTE]
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Glowork ultimate 60ff lighting issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
