L
Lee171181
Hi
I have a problem with the above boiler, it's not sparking or lighting at all. When I turn it on I can hear a humming noise and it clicks on but I can't see any spark and it doesn't light. Have checked pilot is not blocked and also tried replacing the ignition and the pcb, both of which have made no difference.
Te fan has been very noisy recently so could this have failed & be the cause? Is there anyway I can't test this or bypass it to test as its quite an expensive part to replace if that's not the cause?
Thanks,
Lee
Thanks,
Lee
