Discuss Glow worm store 35 f81 code. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Got a problem with above boiler, fault code f81 and discharge from vent, central heating working OK.
I think it may be a faulty temp sensor causing overheating, gauge shows 55degrees.
Any thoughts very much appreciated
Cheers .
Hi all
Cheers .
I think a Gas Safe registered Engineer is the best bet. They should be able to sort that fairly easily.
Glowworm engineer couldnt resolve it either. They have changed heat exchanger, diverter valve. And now think the issue might be with the storage tank.
We are without working boiler for 4 weeks now. Any help would be welcomed. Glow wor engineers are completely useless.
Hi. Appreciate this thread is 9months old now, but was interested if there was a resolution for the F.81 error. I have the same boiler and after 3 cycles of the burner cutting in the boiler goes into error F.81. Only happens on hot water side and is consiistantly after 3 burner cycles. Boiler engineer has been and temp gagues in/out of boiler and tank all ok. Has assummed its a faulty sensor ??
appreciate any update on the original poster issue. thx
Reply to Glow worm store 35 f81 code. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi, My combi-boiler has just given up heating the house and basically only delivers hot water. While in central heating mode it heats up and stops...
I am a new poster to this forum - not a heating professional, but a householder looking for advice. please. I have a Glow worm 18hxi boiler with...
2K
Hello all! Can I please have some professional opinion on our ongoing problems with our Glow-worm Fuelsaver mk11. Now I know the simplist answer...
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached...
2K
