Discuss Glow Worm MICRON 40FF Boiler Replacement in the Central Heating Forum area at PlumbersForums.net
T
taylorX
I'm currently looking for a replacement boiler for a Glow Worm MICRON 40FF. I'm not sure if I need a 15kW or 18kW boiler?
Reply to Glow Worm MICRON 40FF Boiler Replacement in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
