Discuss glow worm flexicom 30cx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
moonlight
Customer rang. Told me she had someone out, they have changed the flat plate heat exchanger. Still same problem with water runs hot for a few minutes, then runs cool. Boiler is still running. Then they have told her its because she needs a new pump and quotes her for one. Then they sent another engineer and told her she doesn't need a pump. I have to go and look at the job today. Is there something I should be checking? I told her son to turn off the valves to the shower but the problem persist. I can only think there must be a blockage in the filter? Any help would be useful. Thanks
If the boiler is still lit then I would be looking dhw temp sensor myself. If it's going out then possible blockage.
Boiler is running at lower temperature. Just rang Glow worm. Suggest rubber hose deterioration, and filter blockage. He said squeeze hose. But that's not going to happen, if slightly blocked that will kill it. New hose then, cheap thing to try first and very likely. Clean filter and off we go. Lets hope. The only other thing is the pump.
Or the sensor as above
Reply to glow worm flexicom 30cx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi Have a Glow worm Flexicom 30cx-Installed 2010 and regaularly serviced. Last service October 21. Works fine, with no issues. However it has...
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse...
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
1K
10 months ago had a new Glow-Worm gas boiler installed in our bungalow. It failed nearly a month ago when a gasket internally in the HW feed cct...
