Discuss Glow Worm Flexicom 15hx Leaking condensate in the Central Heating Forum area at PlumbersForums.net
I have a Glow Worm Flexicom 15hx that is leaking what I assume is condensate from the circled area, is this likely to be from the part of the flue that could also leak CO gas? Would the fix be as straightforward as replacing this plastic part if that is the source of the leak? Thanks!
Reply to Glow Worm Flexicom 15hx Leaking condensate in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
