Discuss Gas valve Vaillant eco tec pro 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Atanas Peev
Hello any with experienced with gas valve low voltage The boiler is Vaillant eco tec pro 24 I’ve got a code F61 and voltage to gas valve solenoid is 4.51v dc
Regards Atanas
A gas safe engineer will be able to diagnose and repair your boiler we cannot give you any advice regarding gas repairs in the public domain on this forum . Apologies kop
He is gas safe lads and tbh don’t know what happened but it appears he’s lost the gsr badge as I’m sure I’m the one who processed it :D
[automerge]1571524819[/automerge]
Check the voltage at the board if the voltage is good there then loom is probably bad if not
Then I would suspect the pcb
Reply to Gas valve Vaillant eco tec pro 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
