Discuss Gas Safe Bulletin TB 118 in the Gas Engineers Forum area at PlumbersForums.net
mutley racers
Subscribed
Hi all. Hope you are all good and are doing ok with work due to lockdown, self isolating etc.
What instruments did people purchase to comply with this bulletin?
I only paid £160 for a fluke 116 last year and now need to spend a lot more due to this bulletin.
Cheers all.
remove fuse spur
prove multi meter
multi meter case to check its not live
done
Multimeters aren’t recommended to dead test for safe isolation anymore. It should be a test lamp or two pole voltage tester to GS38.
I don’t see why not there an approved electrical test device
think it’s another one of those people don’t know how to use them properly so they have kept it simple
I’ve just read the document from hse (4th edition) which appears to have changed to possibly include multimeters? I distinctly remember it stating they shouldn’t be used, as the incorrect selection of range could be used, eg Vdc instead of Vac. It does however state must meet certain criteria. Maybe they changed it as people didn’t want to shell out on new equipment?
Didn’t want to shell out when there was no need to. Learn how to use a multi meter correctly. That’s where they should be focusing.
You got a link to this mate?
All I can find is what you were saying...
Proving electrically dead
Once the means of isolation has been identified and following the isolation of the equipment, it is vitally important the equipment is checked to ensure it is electrically dead before work commences. The use of an approved voltage indicator is required to prove that the equipment is dead; this could be a proprietary test lamp, or a two-pole voltage detector. The HSE recommends that a multi-meter is not used for proving dead (HSG85(2)).
https://www.hse.gov.uk/pubns/priced/gs38.pdf I couldn’t seem to find information regarding not using a multimeter to prove dead, only single pole voltage or non contact voltage indicators. That said, I haven’t read it thoroughly and may have missed it.
Pretty much says what is said above in previous post about people selecting the wrong range with a multimeter so they should not be used. Hmmmm
Reply to Gas Safe Bulletin TB 118 in the Gas Engineers Forum area at PlumbersForums.net
