Discuss Gas outlet in garage in the Gas Engineers Forum area at PlumbersForums.net
Morning all
Is it possible to put a gas outlet (like the gas taps back in school science lessons) or similar in a garage?
Thanks if you can advise.
For what purpose / equipment ?
To attach a 7.5 kW burner to boil an 8 gallon steel pot of water (for home brewing beer!) My kitchen hob is not powerful enough to achieve a rolling boil. And, in any case, when me and my brother take over the kitchen all day on Saturday it's beginning to annoy my wife.
Edit: Something like this (these are advertised as for use with propane/butane bottles):
Sorry to say no (as the one you linked is for lpg)
Might be better off getting a gas cooker installed in the garage instead
Yeah, I noticed the one I showed was for butane/propane, but putting that to one side, is it possible to get a "science lab" gas tap put into a garage? Or a more robust solution, but not as far as installing cooker?
Better on getting a cooker point installed as there designed for your use case
Nice one, thanks Shaun. Ballpark, what you looking at? I know this is a question tradesmen HATE but I have no idea what to budget for it. The gas line actually runs along the inside of the garage wall to the meter that is also in the garage. It also has electric.
Might need to upgrade the gas main due to the extra load so best get a quote also you will require a vent in the wall for replacement air
Dont think your home insurance would pay out.
And i dont think you can fit a cooker in a garage (i would not )
use outside with propane or get electric boiler for wort. hic
Thanks Pete. Insurance was a question mark tbh.
It does seem that butane or propane is an unnecessarily expensive solution. However thanks to all your advice I think the "gas tap in the garage" idea is a no-no.
Thanks again to everyone for helping out.
Please do chip in if anything else comes to mind. Thank you.
Reply to Gas outlet in garage in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
