Discuss Garage workshop heating project in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi chaps,
Have been asked to look at providing heating for a workshop. It is approx 10.5m x 5.5m but runs all the way up to the roof i.e. 7.3m high. The guy has another workshop next door which is heated by 4 rads run off a Grant 50 /70 oil boiler. This workshop has a ceiling however with office space above ( with another 4 rads off same system )
Have done a wee bit of tinkering with various programmes etc and the heat requirement is approx 18000 BTU's - would it be worthwhile installing a boiler , even a second hand boiler , and 3 x 6000BTU rads? Have never had to work with a space so high before…...
many thanks for any suggestions
dave
cast iron pot stove to burn an waste and keep the place warm. you dont mention if the walls are brick or corregated metal so hard to say what to do, especially as your still working in btu.
Im taking out a heat therm oil boiler. Free if you want to collect from the back of beyond.
Heating spaces like that, you may as well burn fivers.
Have a look at radiant heaters, or quartz heaters- heat the people, not the air.
The ambirad site would be a starting point
brick and block walls lameplumb - constructed 2000 so presumably at least some form of insulation involved
Thought of a warm air heater Dave? Warmflow or powrmatic are your boyos here, strip out the boiler and rads and duct one or two of the turrets.
Whereabouts over here are you?
I'm with croppie, a powrmatic or nuway benson would do the trick for you. Either would heat the space quickly. They have oil or gas fired units available.
Could fit a schwank radiant heater but that wouldn't heat the office space
The heat loss calcs are diff aswell. What type of roof and is it an open door garage...or is it an enclosed space?
Have a look at Myson Hi-lines, I did a job recently where the company specified five hi-lines to be fitted in a separate zone in their workshop which was approx 30m X 20m X 10m with two large roller shutter doors at each end, also there was an additional L type space which was at one end which needed heat.
Before anyone jumps in and says not enough heat, I also thought it wouldn't be enough but the company owner explained that they do create some heat through welding and machinery and he didn't want to provide a lot of heat otherwise the lads got lazy.
I fit them all at about 3mts high and ran off the flow and return with its own thermostat/programmer and tbh I was surprised at how warm they made it.
hi croppie - I'm in Antrim. know nowt about warm air heaters and the guy is keen on a boiler / rads as this is what he has in his other workshop. Says it works well for him although this workshop has a standard ceiling with office space above.
cheers
dave
Might be an idea to go with Goz's suggestion Dave.
You didn't wave when I flew past from Londonderry to Belfast earlier today!
Do like Croppie says but don't forget hot air rises like hell off a warm air unit, just like on here, de-strat fan will do the trick
Warm air heater and de-strat fan, or Ray's suggestion of electric radiant or quartz heaters. Can't compare the 2 units if one of them has a second floor, at 7.3m height you've got a lot of space to heat before you'll feel it at floor level. I wouldn't even consider rads.
Reply to Garage workshop heating project in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I would like to add an additional radiator to our central heating system. We have an attached double garage converted to a man-cave and workshop...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2...
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
