Discuss G3 Badge. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
kozak1968
Are you going to issue G3 badges to members? It would make it easier for members to give advise on the subject.
I just noticed that some members are not Gas safe but can give info. Now I know that just because you are Gas safe doesn't mean that you are G3. I think it would help if everyone with G3 had a badge.
It's a fair point, lots of people asking questions lately.
the more badges the better........ive got my blue stripe, apc 2 star and a sticker from the dentist saying i am a good boy :)
Reply to G3 Badge. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
