I have just had a Franke Athena kitchen mixer tap fitted. After turning it off there is a small drop on the spout.
If I remove this then another one will form at some point later (and times between drops appear to get longer)
This morning there was no drop there so I thought it must just be water retained in the neck that was coming out over time but, after 20 minutes without the taps being used, another drop had formed.
All the taps I have in the past did not do this and as Franke is a costlier solution I would not have expected it to do so either.
Is this normal operation for a Franke tap (and if so why?)
If not then I shall have confidence in contacting Franke to sort it.
