Discuss Fostaplast 1/2" class c in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The pipe shown is marked
FOSTAPLAST
BSI 1972
1/2"
Class C B283
Which connectors can be used with this?
Thank you
Just look for connectors for black alkathene plasson or philmac or similar.
If its above ground and needs to look tidy 22mm Compression fittings with 3/4 olives work you would need copper inserts,on 1/2 class C 15mm copper tube with end flanged over works.
Reply to Fostaplast 1/2" class c in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
