Discuss Foam leak from underneath shower tray in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
New shower tray and waste recently installed and thankfully have a cut out in ceiling below from when I was checking it's initial seal, when I spotted yday foam (from shampoo/shower gel) escaping from underneath the shower tray, out the sides of the waste.
I never really liked the initial seal as was just a loose rubber ring on the trap that you screw tight from the tray side to make a seal.
Now after 2-3 weeks of my wife and I using it with no leak, it's worth adding that this only happened when my 18yr old son came to visit and like most teenagers likes to go through their entire thoughts in the shower, ignorant to the current energy crisis. And also no water was leaking, just foam being pushed out where he likes to go through a litre of shower gel per shower 😂
That all said, aside from him changing his ways, what is the best way to improve the seal, can I add silicone to the top of the rubber ring so that when I screw it to the trap it compress and adds additional layer of seal?
Reply to Foam leak from underneath shower tray in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Void under shower former My recently installed solid resin shower tray / wet room former has around 4mm flex across a dinner plate sized area in...
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
