J
John_
I know this is prob personal habit but when soldering which is better - flux inside or outside, i.e female end or male end?
Discuss Flux inside or outside capillary end feed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm on pipe and fitting
The middle bit.which end of the flux brush do you all use to apply the flux ?
the hairy end or the round handle ?
I do that too :lol:
Close to flame, but if hot enough, opposite side also, but as I am sure you know well, not necessary to solder all round, as heat & flux will do the job in a caplilary fitting.solder which end of the pipe/fitting you apply it , on the side where your flame is or opposite ?
Me too. Stuck half my piece (sandwich to non Jocks) down a inch main today. The whole of Alloa could here me shouting and screaming not nice things at a bit of pipe. The joys of plumbing.I usually start swearing if i've got some water there.
i apply opposite site and it does matter as to make sure that fitting/pipe is up to temp as otherwise if fitting/pipe is not fully visible it might not go all the way round
Reply to Flux inside or outside capillary end feed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
