Discuss Flush pipe seal leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all,
New to this forum and new to plumbing. Only just passed Level One plumbing.
I am having to go back and look at a leak from the back of a WC. The flush pipe is chrome and I have replaced the flush pipe concertina seal.
The seal seems to being pushed out of the WC when flushing. The size of the seal seem correct. Any solutions ????
The seal was from Screwfix, but had good reviews.
Did the seal fit tight around the flush pipe ?
Hi
Yes it was a snug fit. Had to use a little soap to help it along the pipe. It felt snug going into the pan too. When I tested it, I noticed the seal had moved a small amount. The WC is fixed firm to the ground, so no movement there. It seems to be the force of water
Common issue with the force of the flush is it clipped / can’t move out eg the flush pipe ?
Clean all the soap off and wipe pipe and seal with alcohol wipe.
Then assemble dry and hopefully stop it happening. Plastic flush pipe works better - but I know customers often prefer chrome.
Hi
No it’s not clipped. I assume you mean the pipe? It’s not clipped to the wall.
Needs to be clipped / something wedged behind to stop it pulling out you could try a jepp cone
Reply to Flush pipe seal leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Sonya K
