Discuss .....flush cone...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
Solutions
anyone seen a mechanical flush pipe cone / washer i can remember seeing one somewhere but i cant think where
Other end
Like this ish with a stainless plate and 3 screws when tightened expanded the rubber
Have used the ones above but never a mechanical one.
Yea had a toilet today that was like 10mm bigger od of the flush cone so had to use the existing and some mastic
Ah, I remember they advertised it by picking the pan up by the flush pipe.
Sorry Shaun I can’t remember what it’s called either!
Bugging me now!
Three Allen bolts and it expanded like a drain bung.....
Bugging me now!
That’s the fecker
I’ll ask at merchants tomorrow, don’t think they sold any so they disappeared.
Expensive, and solving an almost non existent problem - as a lot of these things do... - bit like that fluxinator thing...
Ta even a name would be good
Bugging me now!
Chris Jepp invented it and there is a utube video, I think he trades from Bexleyheath from a plumbing and heating outfit there. Rob Foster aka centralheatking if you do contact him give Chris my regards from API 2006
That is a recurring problem anybody can patent something that does not work or produce something that nobody wants in sufficient volumes to make it viable...Rob Foster aka centralheatking
I’m not saying it doesn’t work, I have no idea but I’m sure it does having held one in my hand.
I’m just saying imho it is unnecessary in as much as a flush cone for less than a quid has always worked for me (and nearly everyone else) - the occasional addition of silicone needed on a poorly formed pan but that’s not a real problem.
So why pay eight times that for the same functionality?
Because I’ve found a pan with a 10mm bigger dia than a normal flush cone
You can put a normal one in a wiggle it around
Our merchants have three sizes of “normal” flush cone. I always found one to fit, I’m guessing it’s not a new installation as pan would come with correct one (usually)
If the jepp one will expand that far - this is definitely a time to use it, I’m not against innovation - far from it.
I would say that is £8 well spent for a secure connection.
Correct changing a concealed cistern as the old one was a siamp one
Can you reuse the flushpipe and cone from the old one?
That’s what I’ve done with some mastic didn’t leak / move but it’s showing it’s age the old rubber one so prepping for a return :D
Reply to .....flush cone...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, just recently everytime I run a bath, flush the toilet, turn in the washing machine or use anything water related my kitchen taps...
Hello, I have a question on flush pressure. When I press the bigger button, there's hardly a flush. I understand that's normal but it's a very...
Can anyone help My shower is warm, but when I flush the toilet or leave the cold tap on, if gets Hotter. The temperature I imagine a shower...
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a...
Hi there, can anybody help? I am trying to buy a replacement toilet flush push button as my current one is broken? However I cannot find the same...
