Discuss flues in car ports in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cdodds2004
hi ive been asked to quote for a BC in and the flue at the moment comes out under a car port, car port roof is almost 2 stories high and roof of it is above the flue by almost 2m, what would you recomend for siting of new boiler, customer states she wants it in existing posistion?
As long as you have two open sides to the car port and you have 200mm and it's a New room sealed fan boiler you will be ok
has to open sides, has gates on each end but still open, and yea it has alot more than the 200mm stated in MI but just wondering peoples take on it, because it does state in MI not reccomended, my gut feeling is that its a big open car port and shouldnt be any problems
Are you gas safe? And it's your call if is says don't then don't but if it's says not recommended it's your call but wot I can see there is no reason why not
Have a look at 5440 and mi. it's all in there.
i wonder if theres a problem with plume condensing on the roofing and dripping down?could you take a plume management kit up thru roof ?
Of the top of my head I think flue's have to be 1200 mm from an opening under a car port
Reply to flues in car ports in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
1K
J
Hi - I'm not sure if this is the right forum or not, but I'm looking for some advice with regards to a recent (nightmare) new gas boiler install...
4K
Mark Butler
M
Hi Could anyone help or advise me please? I have a Black 5'' Convesa Twin Wall Flue from my dining room to outside wall, the flue needs another...
2K
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
Hi All, hoping for some advice and pointing in the right direction. I have a Worcester Bosch 40he condensing boiler, supplying hot water as...
4K
